texasTrio
Jun 30, 2022Aspirant
Orbi Pro - signals flatlining
Still debugging Orib Pro Wi-Fi disconnects. The organization has a router, satellite and two ceiling mounts. Most of the client device are not moving around. The symptoms are random Wi-Fi connected ...
CrimpOn
Jun 30, 2022Guru - Experienced User
texasTrio wrote:
That is when I saw the flatlining signal. From my previous experience, that indicates a bad device.
When I open WiFi Analyzer by Kevin Yuan, I see the same pattern of some WiFi signals dropping to zero and then reappearing. All WiFi signals vary in signal level over time, but only some of them disappear completely. Which app displays "signal noise"?
- texasTrioJun 30, 2022Aspirant
By signal noise, I meant all of the graphs on the display at the same time. 1 router, 1 satellite, 2 ceiling devices, 3 networks, and 2.4 and 5ghz broadcasts, that is 4 devices X 3 networks X 2 ghz = 24 broadcasts. By the other noise, I meant possible electromagnetic interference or short somewhere causing the drops. Bad choice of words.
I don't think it is normal for a broadcast to drop to -100 off the chart. When the satellite is off, the broadcast power is in normal ranges.
