UGAVetDude
Jul 07, 2022Aspirant
Orbi Pro 6 Connection Problem with Server Workplace
Hello, I have the following connection scheme in my veterinary clinic: Internet Router -> Sonicwall -> Server (Windows Server 2018) -> Switches && -> Orbi Router Almost all computers have an...
CrimpOn
Jul 07, 2022Guru - Experienced User
Use the Orbi web interface, the Advanced Tab, Advanced Settings (bottom menu item), then select Router / AP mode and change the Orbi to an Access Point (AP) rather than a router.
UGAVetDude
Thank you. I'll try that when I get back in front of it!
