Beneficia
Jun 18, 2025Aspirant
Orbi Pro 6 (SXR80 - SXS80) Connection with Powerline Adapter
Hi Community, Has anyone had success connecting an Orbi Pro 6 Mesh System Router to a Satellite using a Powerline Adapter? I have a a network setup with an SXR80 and an SXS80 but was having a...
Jun 18, 2025Guru - Experienced User
I've done it with the 30 series.
When you set it up, is it going SXR lan port---->powerline----->powerline----> satellite ethernet?
Have you tried rebooting?
Beneficia
Jun 19, 2025Aspirant
Yes, that is exactly how I have it setup. I did not actually think it would work because the outlets that I am using are on different subpanels, but I was pleasantly surprised when the lights indicates the connection was good.
I am glad that the connectivity is there, but I just don't understand whey the Insight App does not show the Satellite as connected and why it cannot read or display the firmware version. I was thinking perhaps the backchannel communication between the hardware does not work over a powerline connection.
- StephenBJun 21, 2025Guru - Experienced User
Getting a connection is one thing, getting useful speeds is another. I've found that powerline can be very hit-or-miss (and I don't trust the LEDs). That's especially true when the outlets are connected to different subpanels.
If you can connect ethernet to a PC, then I suggest connecting that PC to the powerline connection (not changing the outlet pairs) and running speedtest.
If not, you could connect your router to the satellite powerline connection, and connect the other end to your ISP lan connection. Then run speedtest on the router.
- BeneficiaJun 21, 2025Aspirant
I will definitely connect a laptop and run the speed test. That is an excellent suggestion to confirm the quality of the connection. The other thing that I have noticed is that I have an outdoor WIFI Extender that used to not have any signal, until the satellite came up. It appears that the extender has had a solid connection since configuring. I will also connect to the extender both 2.4 and 5 networks and check the speed tests there too. Thank you.
I think I need to read up on how I can manually update the firmware on a satellite if there is a way to connect to its IP directly.Thanks!
