texasTrio
Jul 06, 2022Aspirant
Orbi Pro AC3000 Tri-Band SRR60 - DoS attacks in log files
I read numerous posts about DoS attacks in the log files. It wasn't clear to me if these are ghost messages are they are in fact DoS attacks and logged correctly. I am chasing Wi-Fi dropping at a chu...
Retired_Member
Jul 07, 2022Hi, I am just a user as well. I also have posted this very same thing on this site.
From what I was told, the router is doing exactly what is was designed to do. The router is picking up this "traffic". Is it blocking it? Yes I believe so. Is it recording it in the log? Yes.
I have had no issues with Netgear (other than some buggy firmware updates in the past). I have now simply disabled the log. There is no need for me to see this. Again, I have no issues with Netgear...maybe someone that is more technical may chime in. But I think you are good. I am not sure if emailing these companies would do any good. Have a great day...
- texasTrioJul 07, 2022Aspirant
So, if they are real DoS attacks, is the Orbi logging after one attempted access or after N attempted and successive accesses?
- Retired_MemberJul 07, 2022That I do not know.
- schumakuJul 08, 2022Guru - Experienced User
Most are not even true DoS attacks - causes are when mobile devices have connections open and disconnect eg due to power saving, connection loss, wireless disconnect, roaming to different SSIDs or AP connections, uplink (Internet connections going down or bouncing).
