rajeshbhat777's avatar
Mar 07, 2023
Orbi Pro AX6000 WiFi 6 Tri-band Router (SXR80)
I have this router with 2 satellites at home. Is there anyway to setup Internet access restrictions for individual devices like my sons Laptop and phone and specify times or time limit per day on internet access? Any help on how to set it up is appreciated.
Thanks
1 Reply
  • michaelkenward's avatar
    michaelkenward
    That is usually achieved with "parental controls". I see no sign that this model supports that feature.
    That range of routers seems to be aimed at the "Pro" market, with none of the stuff you get on domestic kit.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi Pro - WiFi for Small Business - NETGEAR Communities
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
ProSupport for Business
