fixmacs
Dec 26, 2017Guide
Orbi Pro Ethernet connected devices
How do I control access to the Ethernet-connected devices with respedt to the WiFi networks? The Orbi Pro has the feature of creating up to three WiFi networks,. How does the administrator controll L...
- Jan 08, 2018
Okay, I installed the Orbi Pro. My experience with the actual setup was outstanding. The setup procedure, although requring my attention to several details, moved easily through the web interface that automatically appleared on my computer immediately after installing the hardware. Well done, Netgear.
JohnC_V
Jan 01, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
