fixmacs
Dec 26, 2017Guide
Orbi Pro Ethernet connected devices
How do I control access to the Ethernet-connected devices with respedt to the WiFi networks? The Orbi Pro has the feature of creating up to three WiFi networks,. How does the administrator controll L...
- Jan 08, 2018
Okay, I installed the Orbi Pro. My experience with the actual setup was outstanding. The setup procedure, although requring my attention to several details, moved easily through the web interface that automatically appleared on my computer immediately after installing the hardware. Well done, Netgear.
JohnC_V
Dec 28, 2017NETGEAR Employee Retired
Hi fixmacs,
Orbi Pro can support upto 3 WiFi networks, but it will be working on the same network address. So even the ethernet connections are on the same network. Guest network is pretty isolated to other networks even on LAN. It cannot access any other devices inside the whole network.
fixmacs
Jan 02, 2018Guide
Netgear created three possible WiFi networks. The Admin has access to everything. The "Employee" network is managed by the Admin and thus does not have access to all network nodes, and then the Guest network is limited to Internet access only. I would like Netgear to describe these features in greater detail. The FAQs have no information.
- JohnC_VJan 03, 2018NETGEAR Employee Retired
My apologies on that. Yes, you are correct as the Orbi Pro does not support any VLANs.
- JohnC_VJan 08, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- fixmacsJan 08, 2018Guide
