GB-User
Nov 12, 2020Tutor
Orbi Pro Issues with Firmware v2.5.4.104
I have had to go back to the previous firmware as I have had issues with the new version, I have a three unit setup a SRR60, SRS60 & RBS50Y. The SRS60 is connected to the SRR60 via ethernet directly ...
Boomerang3
Nov 12, 2020Apprentice
I guess I'm going to have to back down also. After my upgrade to v2.5.4.104 my SRC60 and SRR60 keep disconnecting from the router SRR60. I've been through everything I can think of. Channels, WiFi conflicts, ect. I posted earlier about my now reluctance to upgrade my Netgear Orbi in the future. Seems like everytime I do, something goes wrong.
Thanks for your post.
Update 1
Just downgraded from v2.5.4.104 to 2.5.3.110 on my SRR60, SRC60, and will do the SRR60 when I feel confident that the downgrade put me back into a stable environment. I'll update in an hour or so, since the v2.5.4.104 was disconnect the SRC60 every 15 mins or so.
