GB-User
Nov 12, 2020Tutor
Orbi Pro Issues with Firmware v2.5.4.104
I have had to go back to the previous firmware as I have had issues with the new version, I have a three unit setup a SRR60, SRS60 & RBS50Y. The SRS60 is connected to the SRR60 via ethernet directly ...
qzkhtw
Nov 14, 2020Aspirant
I have a similar configuration, but with two more SRS60’s. I’ve spent hours troubleshooting and reconfiguring. I’m now going to revert back to the previous version. After spending over a grand for this network, I have nothing but issues with it ( always after a firmware upgrade - it’s never seamless)
- Boomerang3Nov 14, 2020Apprentice
I factory reset and downgraded the firmware to v2.5.3.110 on all three (SRR60, SRS60, SRC60) last night.
Everything was working great until about an hour ago and I got another disconnect on the SRC60, the ceiling sat again. It's the SRC60 that has been disconnecting. After the firmware downgrade everything looked great until now and had a another disconnect.
The link speed of the SRC60 is 1300/1300 and has been stable.
So, I'll give it another day or so and see if I get another disconnect and then, well I guess it's a call to Netgear. I havn't put in a support call yet, because I've tried everything that I can find from pamrameters (using the experiencing here), rebooting, factory reset, and now factory reset with firmware downgrade.
I've got a suspicion that it's either interference or distance. The SRC60 has a great link speed, and is two floors up from the SRR60 router.
- qzkhtwNov 14, 2020AspirantI also did a factory reset on all 5 devices and reverted to v2.5.3.110. This is a newer version from what I was on previously (2.5.3.108), but all 4 satellites have remained online for the past 6 hours. Much better than current version.
