GB-User
Nov 12, 2020Tutor
Orbi Pro Issues with Firmware v2.5.4.104
I have had to go back to the previous firmware as I have had issues with the new version, I have a three unit setup a SRR60, SRS60 & RBS50Y. The SRS60 is connected to the SRR60 via ethernet directly ...
RaghuHR
Nov 16, 2020NETGEAR Expert
Thank you all for reaching us.
Boomerang3 GB-User Could you please share the debug logs from the FW v2.5.4.104? You can download the debug logs by accessing https://< IP address of router/satellite>/debug.htm and click on start capture. Wait for 3-4 minutes before you save. Please upload into google drive and send me link via PM. Boomerang3 Pleae confirm if you are using Insight Manager?
qzkhtw Could you please confirm your issue description with the debug logs? Are you using Insight Manager to manage your Orbi Pro? It is not clear you are also seeing the same issue as like others.
Thanks,
Raghu
GB-User
Nov 17, 2020Tutor
As I have backdated the FW will the debug log help, I cannot run the new release v2.5.4.104 as my network stops working correctly. I can give the current logs but that is on FW v2.5.3.110
