lostgear's avatar
Mar 08, 2023
Orbi Pro Mini includes Satellite as Attached Device even if wired to router
The Orbi Pro Mini Satellite is wired via Ethernet + switch to the same network as the Router (in Access Point Mode).
But in the web interphase under Attached Devices the satellite appears under "Wireless Devices" with SSID (blank) 5G.  Should it not appear under wired because it is using an Ethernet backhaul or do I need to do set it up to create an ethernet backhaul?
  • plemans's avatar
    You put both are wired to a switch.
    Is it going
    gateway---->SRR wan port--->lan port from SRR--->Switch--->Satellites
    I see a lot time where people just connect the SRR to the switch with its wan port and then the satellites.
    It needs to have the SRR wired to the gateway with the wan port and then the srr going to the switch via lan port
ProSupport for Business
