ghstudio
Apr 20, 2023Apprentice
Orbi Pro Mini sxr30 slow wifi
New SXR30 user...just trying to learn before I implement live. I configured as a router (yes, double NAT) and connected to my current router with a cable. I have 500/500 internet service. Connectin...
ghstudio
my laptop does not support wifi 6. I also tried splitting wlan 2 and just connecting to 5g.....no difference. I am not using wifi between satellite and base. I am testing with just one device connected to the Orbi. The orbi should be able to handle 500/500 5g. All tests done with ookla (web).
CrimpOn
Apr 20, 2023Guru - Experienced User
WiFi5 has a maximum theoretical link speed of 867Mbps, which translates into an effective speed quite a bit less.
I'd suggest some internet research, such as https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
Perhaps someone with an SXR30 and fast ISP connection will report their results as a comparison.
