ghstudio
Apr 20, 2023Apprentice
Orbi Pro Mini sxr30 slow wifi
New SXR30 user...just trying to learn before I implement live. I configured as a router (yes, double NAT) and connected to my current router with a cable. I have 500/500 internet service. Connectin...
schumaku
Apr 20, 2023Guru - Experienced User
ghstudio wrote:
(all tests on windows 10 with latest updates). Same computer connects to wireless on my current router and speed tests at 490/490. It's definitely the SXR30 slowing things down.
What link speed does windows 10 show in the wireless settings resp properties? Example from another wireless connection and AP (i understand your wireless client does no AX, and the 240x are double of what your SRX30 can reach), specifically the link speed for send and receive:
SSID: xxxxx
Protokoll: Wi-Fi 6 (802.11ax)
Sicherheitstyp: WPA3-Personal
Netzfrequenzbereich: 5 GHz
Netzwerkkanal: 60
Verbindungsgeschwindigkeit (Empfang/Übertragung): 2402/2402 (Mbps)
Hersteller: Intel Corporation
Beschreibung: Intel(R) Wi-Fi 6 AX200 160MHz
Treiberversion: 22.200.2.1
- ghstudioApr 20, 2023Apprentice
SSID: ORBI26
Protocol: Wi-Fi 5 (802.11ac)
Security type: WPA2-Personal
Network band: 5 GHz
Network channel: 157
Link speed (Receive/Transmit): 866/866 (Mbps)
Link-local IPv6 address: fe80::966e:cec0:dcd1:3c2e%12
IPv4 address: 10.0.0.3
IPv4 DNS servers: 10.0.0.1
Manufacturer: Intel Corporation
Description: Intel(R) Dual Band Wireless-AC 7260
Driver version: 18.33.17.1
Physical address (MAC): AC-7B-A1-36-8F-3F
- schumakuApr 21, 2023Guru - Experienced User
ghstudio wrote:
SSID: ORBI26
Network band: 5 GHz
Based on the wireless client negotiated link speeds (866/866) I would not expect a big impact on performance, similar as you see from using the ISP WiFi router. Possible reasons for slower effective throughput could be concurrent channel usage or interferences. Ensure 80 MHz (four channels!) are free with no other AP active concurrently.
Formally talking, the Intel® Dual Band Wireless-AC 7260 (drivers et all) are EoL / discontinued and in self-service support status, so expected to work as-is, certainly as long as no bigger changes in the specs or unexpected things happen.
