ghstudio
Apr 20, 2023Apprentice
Orbi Pro Mini sxr30 slow wifi
New SXR30 user...just trying to learn before I implement live. I configured as a router (yes, double NAT) and connected to my current router with a cable. I have 500/500 internet service. Connectin...
ghstudio
SSID: ORBI26
Protocol: Wi-Fi 5 (802.11ac)
Security type: WPA2-Personal
Network band: 5 GHz
Network channel: 157
Link speed (Receive/Transmit): 866/866 (Mbps)
Link-local IPv6 address: fe80::966e:cec0:dcd1:3c2e%12
IPv4 address: 10.0.0.3
IPv4 DNS servers: 10.0.0.1
Manufacturer: Intel Corporation
Description: Intel(R) Dual Band Wireless-AC 7260
Driver version: 18.33.17.1
Physical address (MAC): AC-7B-A1-36-8F-3F
schumaku
Apr 21, 2023Guru - Experienced User
ghstudio wrote:
SSID: ORBI26
Network band: 5 GHz
Based on the wireless client negotiated link speeds (866/866) I would not expect a big impact on performance, similar as you see from using the ISP WiFi router. Possible reasons for slower effective throughput could be concurrent channel usage or interferences. Ensure 80 MHz (four channels!) are free with no other AP active concurrently.
Formally talking, the Intel® Dual Band Wireless-AC 7260 (drivers et all) are EoL / discontinued and in self-service support status, so expected to work as-is, certainly as long as no bigger changes in the specs or unexpected things happen.
