Happymak
Dec 30, 2017Aspirant
Orbi Pro missing Daisy Chain topology
Orbi Pro missing Daisy Chain topology is missing Daisy Chain topology in V1.12.1.28 firmware. It's illogical that a "Pro" version of a product misses one important feature of the least expensive mo...
- Dec 30, 2017
Try the debug page. [ip]/debug.htm
tneorg
Dec 31, 2017Aspirant
Hmmm, I just found that on the debug page. Anyone know why it might be there AND disabled?
Happymak
Found a solution thanks to Boomerang3.
First I installed the V1.12.1.38_BETA firmware (sent to me by a Netgear support representative) on my Orbi Pro router and both of the Orbi Pro Satellites.
Then, I tried enabling daisy chain feautre through the [ip]/debug.htm of one of the satellites, but the feature was disabled and locked.
The solution was to enable the daisy chain feature through the [ip]/debug.htm of the router, which allowed the change.
After this, and waiting a couple of minutes, both the satellites had the daisy chain feature enabled and a working connection between the two of my satellites.
Greetings,
Simon
- tneorgJan 02, 2018Aspirant
Are Orbi Pro Beta Firmware updates recommended? Everything is running well now, and I don't want to introduce any issues. Has anyone else upadated to the .38 Beta Hotfix?
