CBIT45
Dec 19, 2020Aspirant
Orbi Pro Router SRR60 won't boot after default
The Orbi Pro Router SRR60 was flashing on the power light that the firmware was corrupt. I was not able to connect to the system so I perfomed a reset. Now the router just blinks with a white ring ...
CBIT45
I was asked to post on this instead because of the model number. It is an Orbi Pro Router SRR60. I found it flashing the red power LED indicating it had corrupted firmware. I was not able to login, connect, or show wifi on it so I used a paperclip and reset it. Upon doing so the power LED turned off and never came back on after 10 minutes of waiting. I then turned the unit off and back on. The power led is now green, but the top ring is still pulsing white as it was before. No change after quite some time. Any help would be appreciated.
Thank you!
- DaneADec 20, 2020NETGEAR Employee Retired
If the ring LED is pulsing white, it means that it is either the SRR60 router is booting or the Sync button was pressed. Is the ring LED still pulsing white until now? If the ring LED is still pulsing white and there is no available SRS60 satellite that it can sync to, I suggest you to open a support ticket with NETGEAR Support here and have it replaced.
DaneA
NETGEAR Community Team
