Marco-F
Feb 12, 2020Aspirant
Orbi Pro SRK60 over two-floor house connected via Ethernet
I'm considering buying the kit of 6 SRK60 Orbi Pro to create a unique WiFi mesh over two floors. I can make use of Ethernet cable to connect the 6 units among them. In fact, not all the rooms are re...
JohnC_V
Feb 13, 2020NETGEAR Employee Retired
Yes! That's possible either you connect it via cable or wireless. As long as it will not over to 8 satellites and everything will be good.
John
NETGEAR Community Team
Marco-F
Feb 13, 2020Aspirant
Thanks for confirming.
I would just add that the Ethernet backhaul can be designed also as a mixture of star and daisy-chain, right?
