JeffFerg
Apr 07, 2022Guide
Orbi pro SRR60 Displays Error in Red below the Internet connection in AP Mode
Please let me know how to correct the situation. Router works in AP but displays the Red Error. Thanks.
- Apr 09, 2022
Glad you got it figured out!
Might mark it solved so others aren't still trying to fix it when you've figured it out.
JeffFerg
Apr 08, 2022Guide
Thanks for all the hints, found the Source of the error. I temporarily disabled the "Intrusion Prevention Service", IPS, on the SonicWALL for the statically assigned IP Address for the the Netgear SRR60-Pro and then the "Red Error" changed to the "Green Good". I then reversed the procedure to keep the IPS Protection active for the downstream devices. The Orbi still works fine.
Thus, the hint of the Orbi "phoning home" could be true, I am still puzzled that the other previously mentioned router makers work fine which to me means that they are not using the same authentication methods.
Thanks again for all the help.
Apr 09, 2022Guru - Experienced User
