rwdozier
Dec 31, 2019Star
Orbi Pro SRR60 missing attached devices
New to Netgear Routers - have an Orbi Pro SRR60 Firmware Version V2.5.0.108 setup and working fine except that in the attached device list there are some missing. Specically, one of four SONOS Play 1...
- Feb 03, 2020
Hi rwdozier cmfnotify Marchal saulos Vintners
Please update your Orbi Pro to the latest FW 2.5.1.106. We have fixed many issues reported earlier on the community. Please reach us if you are seeing any issues after the upgrade.
Download Link:
SRR60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRR60-V2.5.1.106.zip
SRS60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRS60-V2.5.1.106.zip
SRC60 - http://www.downloads.netgear.com/files/GDC/SRC60/SRC60-V2.5.1.106.zip
RBS50Y - http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y-V2.5.1.106.zip
New Features and Enhancements:
- Supports Access Control and MAC ACL in AP mode.
- Optimized connectivity requests to Insight cloud.
- Supports the NETGEAR Insight app and Insight Cloud Portal version 5.8.
Bug Fixes:
- Fixes certificate issue that blocked https login on Chrome.
- Fixes an issue where the local browser UI returns a 500 error due to a memory leak. Note: If firmware update fails, reboot and try the update again.
- Fixes an issue that prevented client access to the Internet. Note: We recommend you open MAC ACL and Access Control configuration and click Save to repair any incorrect settings.
- Correct client information is now displayed in the Attached Devices page when clients connect to RBS50Y wireless 3.
- Enhanced log messages for onboarding the device from the Insight Cloud Portal and Insight app
Known Issues:
- MAC ACL or Access Control can exceed configuration storage capacity with unexpected results in firmware version 2.4.0.114. Workaround: Upgrade to 2.5.1.106, and then go to the MAC ACL and Access Control settings and click Save to reapply the settings.
- After updating router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite. Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
- Clients with hostnames that exceed 32 bytes do not display well in the Attached Devices page. To be fixed in an upcoming release.
RaghuHR
Jan 02, 2020NETGEAR Expert
Hi rwdozier
Do you know which SSID you are connecting your SONOS Play 1? Did you checked the "Allow employees to see each other"option ?
Did you checked with Wireless 1 SSID?
- What do you mean by "screen shot your attached device". Detailed info of the device in the SONOS app? -
Please send me the Orbi Pro attached device screen shot.
- how do you exit/disable the Orbi Pro debug mode once debugging is done?
Once you click on save then it will automatically stop the debug mode.
Thanks,
Raghu
saulos
Jan 03, 2020Aspirant
Hi I have the same situation, but with MacBook pro both are not showing up on the Attached Devices.
I have a SRR60 and SRS60 .
Also 1 OnePlus 6 phone is not showing.
All the devices are connecting fine and from them I can reach the router web interface.
Thanks.
Paolo
- RaghuHRJan 03, 2020NETGEAR Expert
Hi saulos
As mentioned earlier in this thread we need debug logs to invetigate further.
Go to the http://<ip address of orbi pro>/debug.htm. Then click on start capture.
Connect your devices Mac book and other devices.
Wait for the issues to happen and save the debug logs. Please wait at least 5 mins before saving the logs to record everything in the logs.
You can upload debug into google drive and send me link via PM. Mention the MAC address of your devices which are not listed in attached device page.
Thanks,
Raghu
