DeanE79
Jun 25, 2024Aspirant
Orbi Pro SRR60 network set up. Help please
Hi All, I am beyond my technical capabilities here, and looking for some advice on the best/correct settings for what my hardware. Below is my current setup, please excuse me if this the wrong way ...
Jul 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between SRR 📡 and SRS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Can you turn OFF the 2nd SRR and just run the SRS and does the system work Ok?
What channel configurations are currently set on the router?
