harminder_raja
Feb 15, 2021Guide
Orbi pro srr60 not working with mobile app
Last night I update my orbi pro to latest SRR60 / SRS60 Firmware Version 2.6.0.108 after update now my phone is connected to WiFi but unable to locate my orbi pro
- Mar 14, 2021
nyny56 wrote:i have srs60 paired with sxr80+sxs80. they were updated to 3.2.3.100 today.
Sounds very wrong, at least more then odd to me. The SRS60 (that's a router and officially not convertable to a sttellite, too) isn't supposed to be workable as a paired satellite on the Orni Pro AX.
It might work in AP mode as a standalone device, and beeing Insight manageable.
nyny56 wrote:while srs60 seems to function ok as satellite it cant be managed from insight
The SRS60 isn't supposed to work as a satellite to an Orni Pro AX system - so I don't wonder much.
The subject of this post is incomplete - the talk is about the Orbi App ... not Insight.
nyny56 wrote:or from the sxr80 firmware update date.
As above.
nyny56 wrote:sxr80 update page always says it doesnt know what version it is at.
As above. SXR80 does not know about the SRS80 in general.
nyny56 wrote:is there a url to download 2.6.2.200 directly. then i log into srs60 and use its firmware update page in browser.
.200 is released to the Insight managed (complete) Orbi Pro systems.
.200 download links are supplied as a copy here (ignore it's a beta path - it's .200).
nyny56
Mar 13, 2021Aspirant
thank you, but i have srs60 paired with sxr80+sxs80. they were updated to 3.2.3.100 today. while srs60 seems to function ok as satellite it cant be managed from insight or from the sxr80 firmware update date. sxr80 update page always says it doesnt know what version it is at.
schumaku
Mar 14, 2021Guru - Experienced User
As above.
- nyny56Mar 14, 2021Aspirant
thank you very much for the link. that worked perfectly.
srs60 is orbi pro satellite and is able to function as a wired backhaul satellite to sxr80. however, this configuration isnt fully supported; 1. insight recognizes the sxr80 as having the srs60 as a working/connected satellite, but cant manage the srs60 2. sxr80 browser page for attached devices shows the srs60 as attached and a satellite, but doesnt correctly report devices attached to the srs60. wireless devices attached to the srs60 are reported from sxr80 attached devices page as having a blank link status. they are nonetheless attached and can/do function at full srs60 speed.
srr60 is an orbit pro router and i am not aware of any way to make srr60 a satellite of sxr80. the ability to use srs60 as a satellite helped recoup some of my previous investment after upgrade to sxr/sxs80 from srr/srs60.
