Kasselk
Dec 23, 2021Follower
Orbi Pro SRR60 VLAN per SSID
Hi All,
I think I already know that the answer is no but my Orbi pro is connected to my pfsense router and I have configured the router port for three vlans which I was then hoping to then create a vlan per SSID on the Orbi but this doesnt look possible. I know the Orbi can do a MAC ACL to seperate clients but the issue is on the connection to my router that I have no way to keep the traffic coming from the three SSIDs segmented as they will all be in tha IP address range.
My end goal was to have three segmented networks, Private, IOT, and Guest that extended to both WIFI and my router and switch.
Any suggestions?
1 Reply
Not really. To my knowledge, the SRx60 Orbi Pro system is implemented based on the consumer L2 Orbi design - so not a VLAN implementation.
