Dcranford
Apr 18, 2022Guide
Orbi Pro SRX80 download speeds slow
Just installed the Orbi Pro wifi 6 ( SRX80 and 2 satellites). I was originally using the centurylink C3000Z router and an Orbi RBR50. I was getting 800-900Mb/s down and 900+ up constantly. After movin...
Dcranford
Apr 19, 2022Guide
Great questions,
When I put in the new SRX80 I completely took the C3000Z out of the equation so im directly connected to the ONT from the Orbi.
So I did do a direct connect to the Orbi via laptop and still was getting the same numbers, mid to low 400s for download and Mid 900s for upload. I then took the orbi out of the equation and hooked my laptop up directly to the ONT and I am getting around 800 and low 900 download and mid 900s for upload. Somewhere the Orbi router is slowing things down.
Apr 19, 2022Guru - Experienced User
Try factory resetting the orbi?
And what test sites are you using?
- DcranfordApr 19, 2022Guide
I had a heck of a time getting this thing talking directly to the Fiber ONT so I had to do several factory resets already. Ive only had the router up and running for 1 day.
Ive used speedtest app ( the Windows APP not the browser as I know that causes issues ) and the centurylink speedtest.
- plemansApr 19, 2022Guru - Experienced User
Did you setup the centurlylink vlan option?
https://superuser.com/questions/1148268/how-to-ditch-centurylink-fiber-modem
Indeed,
What I learned is that the WAN port has to be in access mode, not trunk mode in order for it to connect.
Then all the other ports are trunked.
That was the only step that differed from all of the sites that talk about how to do that. Because the Orbi Pro is the only Orbi that has that ability im sure thats why its not mentioned much. So that took some trial and error to figure out.
