YesYes6533
Jun 27, 2022Aspirant
Orbi Pro SXR80 Device is Disconnected status
Orbi Pro Router SXR80 in the insight app shows Device is Disconnected status. But wifie is working fine. In the insight cloub portal also it shows Needs Attension. I could not save any new changes. ...
Jun 28, 2022Guru - Experienced User
What modem/gateway is the router connected to?
- YesYes6533Jun 28, 2022Aspirant
Orbi Router is connected to AT&T Cable modem
- plemansJun 28, 2022Guru - Experienced User
What att cable modem? many of them are combo devices and running a double nat can cause insight (and the gui) to think its offline when it isn't.
