hencam
Dec 12, 2022Aspirant
Orbi Pro SXR80 disconnects from internet periodically
I am in the UK and connect to the Internet using a 5G modem. The modem shows good signal and doesn't ever drop the connection. I have the 5G modem set to bridge mode, dhcp, WiFi and routing disable...
DaneA
Dec 22, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Found out from the NETGEAR Support Team that you already have an ongoing support ticket and its going to be re-escalated to the higher tier of NETGEAR Support. You may want to post the progress of your support ticket here.
DaneA
NETGEAR Community Team
