duffytclown
Aug 03, 2022Aspirant
ORBI PRO SXS50 and Netgear Nighthawk AX8 router
I have the ORBI Satellites SXS50 that I am trying to get setup with my Netgear Nighthawk Router currently. Eventually, I am moving it to a Netgear Nighthawk WiFi extender and Verizon MiFi device.
What is the best way to get this established and then how to I check configurations via the phone app or computer. Currently the ORBI phone app (Android) won't pick up the Obri.
You only have the SXS50? Not the SXR50?
Reason I ask is the SXS50 are the satellites. They need a compatible orbi pro router to connect to.
- BruceGuoNETGEAR Expert
SXS50 is only compatible with SXR50. For App management, you need to use "Insight App" for Orbi Pro series.
- duffytclownAspirantThe Insight App says it doesnt support the SXS50.
