mttmaverick
Feb 26, 2023Aspirant
Orbi Pro WiFI 6 AX5400 Dropping Iphone & Ipad off WIFI
Hello friends: I need some help here. I installed a Orbi Pro Wifi AX5400 System in my house. I have it all set-up and the TV's all running off the WIFI is fantastic. No complaints at all. However, th...
Feb 27, 2023Guru - Experienced User
Be you disable any MAC Address Randomizers on the Apple devices:
What model Orbi system do you have? RBK or SX?
I recommend replacing the SB6190 modem. Long standing vulnerabilities with that modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
mttmaverick wrote:
Hello friends: I need some help here. I installed a Orbi Pro Wifi AX5400 System in my house. I have it all set-up and the TV's all running off the WIFI is fantastic. No complaints at all. However, the system keeps dropping our Apple Iphones. It will randomly drop the phone and then it does not recognize the password when you try to click back on WIFI on your phone. I am using an Arris SurfBoard SB6190 Modem. I have comcast service. We have updated the firmware on the Orbi, we also updated our Iphones to the latest Ios. Still it keeps dropping both iphones. Nothing else in the house gets dropped. All TV's, WI-FI Garage Door, Thermostat, NO Problems with any of them.
I hope someone can help!
- mttmaverickFeb 27, 2023Aspirant
I have the Orbi Pro WiFi 6 AX5400 Model: SXR50
I will replace the Modem. Do you have any suggestions?
My home is 2400 sq ft and I am using 1 Satellite. This is an apple only problem. All other devices don't get kicked off.
I changed the 2.4 Channel to 1 and the 5 Channel to 40
- FURRYe38Feb 27, 2023Guru - Experienced User
NGs CM1000/1100/1200/2000 series are good modems. All broadcom based.
Be sure to disable the WiFi Private IP address as well on Apple devices.
- mttmaverickFeb 27, 2023AspirantThe Satellite is about 18-20 feet from the router. Did I read that correctly that they are best at least 30ft away?
Thank you for the info on the modem. And the headsup on the apple products
- Oct 01, 2020Retired_Member
