mttmaverick
Feb 26, 2023Aspirant
Orbi Pro WiFI 6 AX5400 Dropping Iphone & Ipad off WIFI
Hello friends: I need some help here. I installed a Orbi Pro Wifi AX5400 System in my house. I have it all set-up and the TV's all running off the WIFI is fantastic. No complaints at all. However, th...
mttmaverick
Feb 27, 2023Aspirant
I have the Orbi Pro WiFi 6 AX5400 Model: SXR50
I will replace the Modem. Do you have any suggestions?
My home is 2400 sq ft and I am using 1 Satellite. This is an apple only problem. All other devices don't get kicked off.
I changed the 2.4 Channel to 1 and the 5 Channel to 40
Feb 27, 2023Guru - Experienced User
NGs CM1000/1100/1200/2000 series are good modems. All broadcom based.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Be sure to disable the WiFi Private IP address as well on Apple devices.
- mttmaverickFeb 27, 2023AspirantThe Satellite is about 18-20 feet from the router. Did I read that correctly that they are best at least 30ft away?
Thank you for the info on the modem. And the headsup on the apple products
- Oct 01, 2020Retired_Member
