Wizec
Jan 23, 2021Apprentice
Orbi Pro WiFi 6 AX6000 terrible AC range and performance
I've been fighting with the new SXK80 system "NETGEAR Orbi Pro WiFi 6 Tri-Band Mesh System (SXK80)" for the last few days.
tl;dr - I'm returning it today.
I still have an RBK53 system that blows the SXK80 out of the water when it comes to 802.11ac.
For comparison:
My Apple TV 4K could only achieve between 12-28Mbps with 200ms latency and 230ms jitter on the 5G band AC protocol when connected to the SXR80. Placing the RBR50 in the exact same spot as the SXR80, my Apple TV gets 51Mbps with 40ms latency and .78ms jitter.
Similar results with other devices on the AC band. Placing the SXS80 satellite in exactly the same place as my RBS50 satellite, I only get a fair connection.
With the RBS50 to RBR50 I get a strong connection, and devices connected to the satellite perform about 98% of the level of those connected to the RBR50.
I can't believe the terrible AC signal, high latency and low throughput of these "Pro" devices.
- RaghuHRNETGEAR Expert
Hi Wizec
Could you please help us to provide more info?
- What is the distance between router and satellite? I mean the physical disatance between SXR80 and SXS80?
- Please share the firmware version installed on RBK53 and SXK80?
- Please provide RSSI value for the link status.
- Share the mode detail of your Apple TV and AC clients.
- Need your deployment diagram as well.
- And lastly we need debug files. Please go to https://< IP address of SXR80/SXS80>/debug.htm, Click on start capture and then wait for the issue to happen before saving debug logs. Send me the link to download via PM.
Thanks,
Raghu
Hi Wizec
Do you have any input for my previous queries?
You need to move around Satellites for the better performance.
The antenna is not same between SXK80 and RBK53.
So you need play with router and satellite placement.
Also make sure you only one Orbi Base in your network at a time. Dont put RBK53 router and Orbi 6 router at the same time.
Feel free to reach us if you have any questions.
Thanks,
Raghu
- WizecApprentice
Thanks, but absolutely not. I spent half a day fighting this garbage. My time is with more than that to me.
I will not spend over $800 on a "professional" WiFi system upgrade that has admittedly worse antennas and WiFi range than a 4yr old consumer product. Get real.
I've already returned the product. I'm done with Netgear as a brand. First impressions are the most important. Netgear releases beta quality, inferior products and charges sky high prices.
