JasperC
Aug 28, 2021Tutor
Orbi Pro WiFi 6 (SXK80) AX6000: Unknown Devices that begin with DEV.
All known devices are defined already. I believe the devices that are unknown are related somehow to the router, i.e. not a device that I have not defined. At orbinlogin.net, go to Advanced > Se...
- Aug 30, 2021
JasperC wrote:
Yes, under LAN setup, each LAN is 10.0.0.1, 10.0.10.1, 10.0.20.1, 10.0.30.1. DHCP Server range = 2 - 254. I just thought it was odd. Perhaps it is required for the router LANs to function. I was just wondering about it and Netgear support couldn't explain it.
Of course each network resp. each VLAN the router requires an address in the local IPv4 subnet ... so no "perhaps"
JasperC wrote:
So I didn't know if it was related to telemetry. I have been advised to watch out for telemetry being default enabled on Netgear routers.
Of course it's mandatory for the LAN operations 8-)
And of course it should not be listed as connected devices in neither the local Web UI (-> BruceGuo pls.) nor in the cloud with the Insight App or Web portal.
JasperC
Aug 29, 2021Tutor
Yes, under LAN setup, each LAN is 10.0.0.1, 10.0.10.1, 10.0.20.1, 10.0.30.1. DHCP Server range = 2 - 254. I just thought it was odd. Perhaps it is required for the router LANs to function. I was just wondering about it and Netgear support couldn't explain it. So I didn't know if it was related to telemetry. I have been advised to watch out for telemetry being default enabled on Netgear routers.
schumaku
Aug 30, 2021Guru - Experienced User
