Retired_Member
Nov 20, 2022Orbi Pro WiFi 6 (SXK80 upload speed
Hi running SXK80 with the latest firmware 4.2.3.103 on Comcast with 1gb down and 30 up. When I test my speeds on the router's built in test results of 950mb down 40 up. When I use most any test (most...
DaneA
Nov 23, 2022NETGEAR Employee Retired
Retired_Member,
Welcome to the community! 🙂
I would assume that you have mistyped the firmware version. The latest SXK80 firmware is v4.2.3.102.
Is the SXR80 configured as Router mode and deployed as the main router?
Is the SXR80 behind another router?
DaneA
NETGEAR Community Team
- Retired_MemberNov 23, 2022
as a router
It is the main router connected to a netgear modem Cm1000
- DaneANov 24, 2022NETGEAR Employee Retired
Retired_Member,
Let us try to perform a factory reset on your SXR80 then observe if the same problem will occur. If the same problem will happen, it would be best to open a support ticket with the NETGEAR Support Team here at anytime for further assistance.
DaneA
