Anonymous
Nov 20, 2022Orbi Pro WiFi 6 (SXK80 upload speed
Hi running SXK80 with the latest firmware 4.2.3.103 on Comcast with 1gb down and 30 up. When I test my speeds on the router's built in test results of 950mb down 40 up. When I use most any test (most...
Anonymous
Nov 23, 2022It is the main router connected to a netgear modem Cm1000
DaneA
Nov 24, 2022NETGEAR Employee Retired
Retired_Member,
Let us try to perform a factory reset on your SXR80 then observe if the same problem will occur. If the same problem will happen, it would be best to open a support ticket with the NETGEAR Support Team here at anytime for further assistance.
DaneA
NETGEAR Community Team
