lostgear
Mar 07, 2023Star
Orbi Wifi Pro mini appearing as device in VLAN
I am using the SXK30 as an AP and created 2 VLANS (i.e. home (VLAN ID1), guests (VLAN ID 20)). It is working well, however, when I check my router the SXR30 (the main unit) appears under the devi...
NiveditaP
Apr 03, 2023NETGEAR Employee Retired
Hello lostgear
And welcome to the NETGEAR Community! 🙂
Is this your topology?ISP -> SXK30 (main router ; vlan 1 and vla20 ) -> SXK30(AP)
Now SXK30 AP appearing in both VLAN1 and VLAN20 connected client list?
If so what is the SXK30 master port configuration : trunk/access and VLAN configured on port to which SXK30 AP is connected?
Have a lovely day,
Nivedita Pa
Netgear Team
lostgear
Apr 03, 2023Star
Hi,
Thanks for the reply. It is in AP mode.
ISP-Router-Swtich Port 1------SXR30 Port 1 (LAN)
Switch Port 2 - SXS30 Port 1 (LAN)
