dir
Mar 06, 2020Apprentice
Outdoor light schedule sucks
How can I set up the outdoor unit's light to be on overnight, say from 7pm until 6am? The light's primary usability is art night (obviously) but the scheduling system doesn't handle the concept of ...
- Mar 08, 2020
Hi dir,
Thank you for reporting this problem. I can reproduce it. I'll file a bug to engieer team.
Orbi Pro admin GUI allows you to create multiple schedules. So you can create two schedules - 7pm ~ 12 middle night and 12 middle night ~ 6am as a workaround. Sorry for the inconvenience.
Thanks,
-Leia
Leia
Mar 08, 2020NETGEAR Employee Retired
Hi dir,
Thanks,
-Leia
dir
Mar 08, 2020Apprentice
Thanks for that. Just an FYI though. I can't create a schedule that ends at midnight ("1200am") because "Start time must be before end time ". The latest you call go is 1130pm. So there's a strange undefined 30 minutes between schedules.
Not that important. Just sayin.
- schumakuMar 09, 2020Guru - Experienced User
Correct, this is reflecting the broken design 8-/
