dhey
Dec 03, 2020Follower
RBS50Y won't stay connected
I have a SRR60, 2 SRS60 (wired backhaul) and 2 RBS50Y's setup with daisy chain. The on all devices are at FW V2.5.4.104. The RBS50Y's will not stay connected even when placed right within 5 feet ...
mindgrape
Dec 03, 2020Tutor
I have a similiar problem, have upgraded to 2.5.5.100 but still same issue. I have opened a ticket with Netgear support - will let you know if things resolves at my end.
Mikael
- ralwetDec 03, 2020Tutor
I own 1 SRR60, 1 SRS60 and 1 RBS50Y. I have exactly the same problem with the RBS50Y. Somewhere I found a hint that older firmware versions run more stable than the new ones. In desperation I installed the firmware versions backwards. Down until version V2.5.2.104. If I run the whole system with this version the RBS50Y connects stable for up to 13h. But then it reconnects again. But at least I can live with it...
