rwdozier
Dec 31, 2019Star
Orbi Pro SRR60 missing attached devices
New to Netgear Routers - have an Orbi Pro SRR60 Firmware Version V2.5.0.108 setup and working fine except that in the attached device list there are some missing. Specically, one of four SONOS Play 1...
- Feb 03, 2020
Hi rwdozier cmfnotify Marchal saulos Vintners
Please update your Orbi Pro to the latest FW 2.5.1.106. We have fixed many issues reported earlier on the community. Please reach us if you are seeing any issues after the upgrade.
Download Link:
SRR60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRR60-V2.5.1.106.zip
SRS60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRS60-V2.5.1.106.zip
SRC60 - http://www.downloads.netgear.com/files/GDC/SRC60/SRC60-V2.5.1.106.zip
RBS50Y - http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y-V2.5.1.106.zip
New Features and Enhancements:
- Supports Access Control and MAC ACL in AP mode.
- Optimized connectivity requests to Insight cloud.
- Supports the NETGEAR Insight app and Insight Cloud Portal version 5.8.
Bug Fixes:
- Fixes certificate issue that blocked https login on Chrome.
- Fixes an issue where the local browser UI returns a 500 error due to a memory leak. Note: If firmware update fails, reboot and try the update again.
- Fixes an issue that prevented client access to the Internet. Note: We recommend you open MAC ACL and Access Control configuration and click Save to repair any incorrect settings.
- Correct client information is now displayed in the Attached Devices page when clients connect to RBS50Y wireless 3.
- Enhanced log messages for onboarding the device from the Insight Cloud Portal and Insight app
Known Issues:
- MAC ACL or Access Control can exceed configuration storage capacity with unexpected results in firmware version 2.4.0.114. Workaround: Upgrade to 2.5.1.106, and then go to the MAC ACL and Access Control settings and click Save to reapply the settings.
- After updating router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite. Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
- Clients with hostnames that exceed 32 bytes do not display well in the Attached Devices page. To be fixed in an upcoming release.
Vintners
Jan 06, 2020Apprentice
Since the Firmware update, no devices are visible!
Everything was running smootly before this update, so can the Netgear guys fix it ASAP?!
rwdozier
Jan 06, 2020Star
When I click refresh, it takes about 15 seconds for about 20 devices to listed. Vintners
As I mentioned in my first post, I am new to Netgear routers and started with Orbi Pro SRR60 Firmware Version V2.5.0.108 so I wouldn't know if it all devices were listed correctly.
I do wish that the device list was a bit more compact without the big fat graphic in the device name!
...Bob
- VintnersJan 06, 2020Apprentice
Oh you are lucky, I just get the 'please wait' message - no devices visible!
- RaghuHRJan 09, 2020NETGEAR Expert
Thanks for your debug logs. We found few areas where we can see attached devices are not shown or few devices are missing from the attached device list page. We are fixing this issue in our upcoming releases. Release date is tentative for now. But will update here once we release officiallly.
Thank you once again for your patience & support.
Raghu
- saulosJan 09, 2020Aspirant
Thanks a lot.
