rwdozier
Dec 31, 2019Star
Orbi Pro SRR60 missing attached devices
New to Netgear Routers - have an Orbi Pro SRR60 Firmware Version V2.5.0.108 setup and working fine except that in the attached device list there are some missing. Specically, one of four SONOS Play 1...
- Feb 03, 2020
Hi rwdozier cmfnotify Marchal saulos Vintners
Please update your Orbi Pro to the latest FW 2.5.1.106. We have fixed many issues reported earlier on the community. Please reach us if you are seeing any issues after the upgrade.
Download Link:
SRR60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRR60-V2.5.1.106.zip
SRS60 - http://www.downloads.netgear.com/files/GDC/SRK60/SRS60-V2.5.1.106.zip
SRC60 - http://www.downloads.netgear.com/files/GDC/SRC60/SRC60-V2.5.1.106.zip
RBS50Y - http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y-V2.5.1.106.zip
New Features and Enhancements:
- Supports Access Control and MAC ACL in AP mode.
- Optimized connectivity requests to Insight cloud.
- Supports the NETGEAR Insight app and Insight Cloud Portal version 5.8.
Bug Fixes:
- Fixes certificate issue that blocked https login on Chrome.
- Fixes an issue where the local browser UI returns a 500 error due to a memory leak. Note: If firmware update fails, reboot and try the update again.
- Fixes an issue that prevented client access to the Internet. Note: We recommend you open MAC ACL and Access Control configuration and click Save to repair any incorrect settings.
- Correct client information is now displayed in the Attached Devices page when clients connect to RBS50Y wireless 3.
- Enhanced log messages for onboarding the device from the Insight Cloud Portal and Insight app
Known Issues:
- MAC ACL or Access Control can exceed configuration storage capacity with unexpected results in firmware version 2.4.0.114. Workaround: Upgrade to 2.5.1.106, and then go to the MAC ACL and Access Control settings and click Save to reapply the settings.
- After updating router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite. Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
- Clients with hostnames that exceed 32 bytes do not display well in the Attached Devices page. To be fixed in an upcoming release.
cmfnotify
Jan 28, 2020Aspirant
I have noticed that since the last firmware update that both stores I have these system setup at no longer have working captive portals. The IOS devices and mac computers just continue to ask users to accept even though they do click accept. They are stuck in an endless loop. I also have issues where I can only access my orbi routers using Firefox because certificates from Netgear are not trusted. Is there a known issue with how the Orbi Pro captive portals are working with newer browsers and is this related to certificates? Will a fix be forthcoming? I have the latest firmware and my routers updates automatically.
Thaks
rwdozier
Feb 01, 2020Star
Close, but no cigar! Updated the SRR60 firmware this morning to Router Firmware Version V2.5.1.106 and the missing wireless device now shows up in the attached device list, BUT now!, there is a wired attached device not showing up that was in the list on the previous firmware version. I will submitting a debug log to RaghuHR within a day or so.
Also, I also really believe the attached device list layout is just bloated and not consice enough at all. Lots of redundacy on the page and who needs graphics for the attached device list on a "PRO" model, really? I will be submitting a "feature request" for a better attached device list soon. I think the 'search' feature of the attached device list page is broke as well.
Anyone else want to chime in?
...Bob
