hugo55
May 29, 2023Tutor
Satelite sharing wifi without password
I build up the network with SXR50 and SXK50. Both device got the error message like [Failed to update GUI language, please wait]. And the satelite is sharing the wifi without password, i dont know h...
BasuKhodanapur
May 29, 2023Apprentice
Hi hugo55 ,
Thanks for connecting to Netgear community forum.
Yes, there is an option to reset Satellite using pin. There is a small hole next to power input.
Router or Satellite to its factory settings. Use the end of a paper clip or a similar object to press and hold the Reset button on the back of the router or satellite for at least seven seconds. The router or satellite resets and returns to the factory settings.
Blinking amber: The router or satellite is resetting to factory default settings.
Please refer screenshot.
If you still have a issue, please pm me or will connect over zoom call.
Thanks,
Basavaraj
hugo55
May 29, 2023Tutor
I did tried to reset for several time
