hugo55
May 29, 2023Tutor
Satelite sharing wifi without password
I build up the network with SXR50 and SXK50. Both device got the error message like [Failed to update GUI language, please wait]. And the satelite is sharing the wifi without password, i dont know h...
hugo55
May 30, 2023Tutor
Hi, just check the firmware has been update automatic, the GUI language can be upgrade.
But the wifi network [ORBI96] still sharing without password.
I tried to connect with my phone and check the console shows that it is connecting to the network [4] belong to Orbi Pro SXK50 Satellite-1.
I have check all the wireless are using different password. Both wireless 1-4 are need password to connect.
BruceGuo
May 30, 2023NETGEAR Expert
Firmware v4.3.1.106 has a related bugfix. Can you check router and satellite upgrade to the version?
- hugo55May 30, 2023Tutor
Please note both router and satellite has been update to the latest firmware automatic.
I had disable the auto update function but did not work.
I am very disappointed about that it can't be use the Asuswrt-Merlin, so much bugs appears and I have no choice to decide to upgrade.
- BruceGuoMay 30, 2023NETGEAR Expert
Is the router managed by Insight?
Can you PM me debug data to analyze root root?
1. Login to Router and Satellite debug page https://<ip address of SXR80/SXS80>/debug.htm
2. Click on start capture and wait for few mins before you save the debug logs. Collect the debug logs from satellite as well.
NETGEAR Bruce
