Andrew1918
Apr 24, 2022Aspirant
Setting up the SXR80 to Telstra NBN HFC I Australia
Hi
I am trying to setup the SXR80 directly to the Arris CM8200 with Telstra HFC NBN.
TPG show how to set it for other modem,but there are no option to set the Vlan priority .Can anyone show how to do it?
Regards
Can anyone help me ?
Regards
thank you
asked Telstra ,I don't need to set anything,
I turn off the modem for 10 mins ,turn it back on plug the orbi to it,it work.
- JohnC_VNETGEAR Employee Retired
Hi Andrew1918,
Welcome to our community! 🙂
It seems that you are having issues with the SXR80. May I know if you want to assign a VLAN on the WAN? Is the Orbi Pro assigned as a router or as an access point? May I know what do you want to achieve here?
John
NETGEAR Community Team
- Andrew1918Aspirant
hi
i want to as router in Australia.
- DaneANETGEAR Employee Retired
Be informed that there is no option to set a VLAN Priority in the SXR80.
From this part of your initial post, it seems that VLAN Priority is a setting that needs to be configured on the modem. Since TPG showed to you how to set VLAN Priority on their modem, I suggest you to contact Telstra HFC NBN and ask for assistance in setting VLAN priority to the Arris CM8200.
DaneA
thank you
