Xavez
Mar 20, 2023Aspirant
Slow connection to work VPN
I know this is an older topic, but I wanted to mention that I have the exact same problem with the Orbi SRR60+SRS60 (aka SRK60). I have tried almost everything by now, but whatever I do: using a VPN ...
CrimpOn
Mar 20, 2023Guru - Experienced User
I think you are correct that this topic has not been satisfactorily explained. Sometimes, "same problem" might be "mostly" the same but have slight differences.
In this case, more detail about how speed is being measured could be helpful.
My guess is the comparison is between speed of connection to work resources:
- When connected directly to the ISP device (modem, ONT) vs.
- When connected directly to the Orbi router by cable (not WiFi, not satellite).
- Sort of surprised that typical tools such as Ookla Speed Test would function when connected through a tunnel to a corporate resource. What tool is being used to measure speed?
Correct?
Xavez
I don't know what happened, but suddenly the parent topic (the one I originally replied to) has disappeared, so my message is missing all context.
In any case, see this topic I posted a few days ago with more context.
- CrimpOnMar 20, 2023Guru - Experienced User
Thanks for the reference. I was going off in the wrong direction by focusing on "Work VPN".
