Ekiz's avatar
Ekiz
Guide
Sep 05, 2018
SRR60 — Orbi Pro. Sattelite not showing up when logged in from webbrowser, But is visible in app
After struggling to try to re-add the satellite when I thought it has lost its connection to the router without success, I installed the Orbi android app, and there it appears. If I check with a W...
  • DaneA's avatar
    DaneA
    Oct 16, 2018
    Hi @Ekiz,
    A new firmware has been officially released for the Orbi Pro WiFi System which is firmware v2.2.1.210.  I suggest you to upgrade the firmware of both Orbi Pro router & satellite.
    You can download firmware v2.2.1.210 on this link.  Let us know the results.
    DaneA
    NETGEAR Community Team
ProSupport for Business
