StephaneLO
Jul 07, 2022Aspirant
SRR60 - WiFi Connecting Behavior
Hi, Dear Netgear community here below an scenario describing strange behavior. We are using the SRR60 base with 5 SRS60 satellite, we choose those device for the WLAN Mesh and roaming purpose. ...
StephaneLO
Jul 18, 2022Aspirant
Hello DaneA,
I started firmware update last week and I will complete update process on Orbi Base today.
After that, I'll will try again with the described scenario and I'll post the result there.
Wait and see.
Thank you DaneA for your help.
Best regards,
StephaneLO
StephaneLO
Aug 02, 2022Aspirant
Hello,
We upgraded the Orbi system version to 2.7.2.102 but we didn't notice any improvment.
When we proceed to the initial scenario, the roaming don't work as expected.
I mean, when the laptop is connected to the WLAN, while we are roaming around the head quarter office, the computer do not connect to the best SSID signal.
Do you have any suggestion to help us ?
Thank you in advance.
Best regards,
StephaneLO
- askvictorAug 03, 2022Initiate
This can be caused by the client (i.e. laptop) not switching to the strongest signal. It might be possible to increase the 'roaming aggressiveness' in the wifi adapter settings in Windows. Also make sure the laptop OS and it's drivers are updated.
- DaneAAug 04, 2022NETGEAR Employee Retired
There are scenarios wherein If the wireless client (like your laptop) wants to stick to the previous AP or satellite even though another AP or satellite is closer to it that provides better signal, then it will still stick to the previous AP or satellite. There are no settings on the Orbi Pro device that can be configured about that.
Just to add with what askvictor mentioned, here below is a sample screenshot where you can check the Roaming Aggressiveness on the setting of the WLAN adapter of your laptop:
The value set to "Medium" as shown above is usually the default setting.
DaneA
NETGEAR Community Team
