Cheezdoodlez
Mar 18, 2021Star
SRR60 dropping connection and DNS since 2.6.x.x updates
All firmware versions 2.6.+ have destroyed my Orbi TriBand SRR60. I have packet loss, but what's worse is it can't hold DNS. I've let it use the carrier's DNS server, quad 1s, quad 8s, and OpenDN...
Retired_Member
Mar 18, 2021Its buggy firmware....again......this is the second release of buggy firmware......
You will probably will be asked to send a debug log......typical response from net gear....
I even think they test firmware before releasing it.....
Suggestion,,,,,downgrade to the previous firmware....
BruceGuo
Mar 18, 2021NETGEAR Expert
Is the AP managed by Insight?
- CheezdoodlezMar 19, 2021Star
BruceGuo wrote:Is the AP managed by Insight?
No I manually manage it.
- BruceGuoMar 19, 2021NETGEAR Expert
We are suspecting a software bug triggered by daylight saving starting from Mar 14 in the US timezone.
Can you help me confirm the issue is gone by changing the value from “0:00 am” to “1:00 am” in traffic counter setting (or you can disable it if you don't use it). See below picture.
BruceGuo wrote:We are suspecting a software bug triggered by daylight saving starting from Mar 14 in the US timezone.
I'm assuming I need to upgrade back to the latest to try this?
Since I'm currently in a stable environment for work running v2.5.5.100 I'll have to wait until after 5pm Eastern before upgrading and trying.
I won't lie, I feel like I'm going to break my stuff again, because this has been going on before DST, but for the sake of troubleshooting I'll give it a try for you.
