overstockoutlet
Jul 02, 2021Follower
SRR60 Drops all Internet Connection when Wired SRS60 are attached
Hello, I would pull out my hair if I was not bald. Bought SRR60 and 3 Sattelites about a year now. Wireless was OK but nothing consistant and signal never stellar. Downloaded newest updated ....
Retired_Member
Jul 12, 2021Hi. FW 2.6.xxxxxxxxx. is completely buggy.....its a disgrace to netgear.....great hardware but really sloppy software....
Down grade to 2.5.5.100....
Manually install the 2.5.5.100 onto the router and the satellite.
It is airly easy to do...
I also have backhaul to my satellite.....and is works great.......
This is my second experience with Netgear bad FW.....and they now it is extremmly buggy....
And they keep asking for the log files.....but do nothing.......
reach out if you need to.....
Cheers
dH
- Retired_MemberJul 12, 2021Whoops - type-o.....Fairly. not airly...... A finger flub caused my wine.....hahah
