Ayediosmio
Feb 03, 2022Guide
SRR60 Gigabit Wired Speeds
Wired connection on SRR60, FW V2.7.0.122, Windows PC. I'm only getting 5-600 Mbps download. I replaced an ASUS GT-AC5300 that had stability issues with the Orbi, no other changes to the environment, ...
Refuj
Jul 21, 2022Aspirant
Please do share if there is any resolution to this. Thanks
Ayediosmio
Jul 21, 2022Guide
Hi Refuj,
I've been going back and forth with Netgear support for 6 months and have no resolution yet. Last update was that Netgear was able to reproduce the behavior and the engineering team is working on finding a fix.
- RefujJul 21, 2022Aspirant
Thank you kindly 🙂
- AyediosmioAug 24, 2022Guide
Adding an update here in case anyone comes across this thread in the future as my case has finally been closed.
The final answer is that this equipment is NOT gigabit. The router cannot provide gigabit speeds. You never get gigabit speed in any real sense beyond the standard marketing bull*** that companies use to try and trick non-technical consumers by combining multiple sources of traffic and adding those speeds together to make up some fake speed. Typical business jargon like a group a 5 toddlers saying they have a combined 10 years of drawing experience. Is the statement true in some sense? Yes. Is the output going to look like a drawing that has 10 years of experience behind it? Absolutely not.Looking back at the title of the product and how its marketed, they refer to it as a "Gigabit WiFi System" where as I was incorrectly expecting a "Gigabit Router" as I had no previous experience with mesh "systems". Not sure how it took 6 months of back and forth and a discussion with engineering to essentially say "Gotcha!" but I guess that is the beauty of marketing, you just keep polishing that turd so your sh** eating grin makes sense.
Hope this helps someone else avoid these products, and helps the troglodyte that initially replied asking about my modem.
Official important clip of wording from support: "we cannot get 1G for this traffic due to a limitation on the platform. However the SRR60 can use the full 1Gbps when using multiple sources,..."- Brown258Aug 25, 2022Aspirant
Ayediosmio LHI Provider Portal Website wrote:Adding an update here in case anyone comes across this thread in the future as my case has finally been closed.
Official important clip of wording from support: "we cannot get 1G for this traffic due to a limitation on the platform. However the SRR60 can use the full 1Gbps when using multiple sources,..."Thank you for the explanation. It is clear for me.
