aalrashid
Apr 11, 2025Aspirant
Srr60 help
I got a technician and he changed the router to AP mode via ip address login. How can I change it back since the up has changed. I can access to the satellites but not main router
Apr 16, 2025Guru - Experienced User
Any progress on this?
aalrashid
Apr 16, 2025Aspirant
Yup I had to rest my system and it’s good for now
- FURRYe38Apr 28, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
