swiftgc1b
Nov 13, 2022Tutor
srr60 pro-- router connects, gives NOT PRIVATEmessage
Bought this router used, trying to setup. It shows connected but all I get is "Connection is not private". Will not go on internet. Is there something I should look for? I can't get on orbilogin ...
- Nov 14, 2022
Mr. CrimpOn, Thank you so much for sticking with me and solving my Orbi problem. The last response you sent was most helpful. I typed 198.168.1.1 and then the link to orbilogin and it worked. I followed the page 27 instructions for safari all seems well now. thank you so much, I think I'm going to like this Orbi, speed on wifi is 250 mbps. Thank you, thank you. Respectfully, swiftgc1b
swiftgc1b
Nov 13, 2022Tutor
I'm not computer savvy. I plugged my ethernet cable back into my modem to get back on this site. When plugged into the Orbi I got a message "Safari could not find the server". I've tried chrome, no difference. I'll need specific steps if you can help. The menu at top right of computer shows a strong wifi signal.. Thx
