swiftgc1b
Nov 13, 2022Tutor
srr60 pro-- router connects, gives NOT PRIVATEmessage
Bought this router used, trying to setup. It shows connected but all I get is "Connection is not private". Will not go on internet. Is there something I should look for? I can't get on orbilogin ...
- Nov 14, 2022
Mr. CrimpOn, Thank you so much for sticking with me and solving my Orbi problem. The last response you sent was most helpful. I typed 198.168.1.1 and then the link to orbilogin and it worked. I followed the page 27 instructions for safari all seems well now. thank you so much, I think I'm going to like this Orbi, speed on wifi is 250 mbps. Thank you, thank you. Respectfully, swiftgc1b
swiftgc1b
Nov 13, 2022Tutor
I factory reset again, 2nd time. Connected ethernet cable to router. tried browser -inop again. Checked router address it is 192.168.1.1 Got message the connection is not private. Never goes to the orbit login site and opens it. Thx again
swiftgc1b
Nov 13, 2022Tutor
Now I just noticed from my top rt. dropdown menu on the iMac. Preferred network is Orbi 92 IP address is 192.168.1.4 not (192.168.1.1) router 192.168.1.1 That make any sense?
- CrimpOnNov 13, 2022Guru - Experienced User
Yes, it does. The Orbi router's DHCP service provided the iMac with:
- Your preferred IP address is 192.168.1.4
- The subnet mask is 255.255.255.0
- The IP address of the gateway to the internet is 192.168.1.1 (the Orbi router)
- The preferred DNS server IP address is 192.168.1.1
So far, that all seems correct. Troubling that the Orbi web browser interface is not responding.
