Someone42
Apr 23, 2020Aspirant
SRR60 Random Factory Reset
Hi, I've had an Orbi Pro for a couple of years now, and for the first time this week, the router decided to factory reset itself. I am on fw V2.5.1.106 and auto-update was active, but the rel...
- Apr 27, 2020
See the attached screenshot where you can take a config backup. You can upload the backup config file onto google drive and share me link via PM. We will check if any configuration is causing factory reset. BTW - Did you upgraded to 2.5.2.104?
Someone42
Apr 24, 2020Aspirant
Thanks for your reply,
1. Are you asking for the "NETGEAR_SRR60.cfg" file generated by Advanced/Administration/Support/Save Debug Log function?
2. That would explain that part. I'm assuming passwords were grand-fathered until I had to set a new one.
I only have one satellite and both the router (SRR60) and satellite (SRS60) are running firmware V2.5.1.106.
SD
RaghuHR
Apr 27, 2020NETGEAR Expert
